Will you have to change vesc settings when you switch from 6S to 12S?
Yeah but there’s going to be another system parallel with this one with both receivers on the same channel
I ran in too many problems with having 6 and 12s on a switch but if you put the y harness on the outside you could easily switch between the series and parallel harnesses. I’m not sure if I’m going to do that yet. I baught an electric switch because the loop key design looks messy.
This is the best voltmeter I could find with the required volt and amperage rating. http://www.ebay.com/itm/DC-0-01-400V-0-1-300A-Wireless-Digital-Ammeter-Voltmeter-Watt-Power-Meter-K6I3-/192033533337 I’d need the larger one to keep up with my battery but it’s huge compared to others I’ve seen. Anyone have any better ideas? this seems like it’s a little overkill
