Under full thottle voltage sags from 47.4V to 42.5V, is this a normal behaviour or I’m pushin my luck here? Even though, battery max has been restricted to 40A on ESC tool it draws 61.2A on each VESC.
hey alan, this is nearly identical to the question i had as well:
if you’re using a bms for both charge and discharge, yes, the sag can be a problem.
if the voltage sags below your bms cutoff, the bms will cut power. usually, when you pack is at max sag will be when you’re demanding the most from it, like hard acceleration. my bms cutout during full throttle uphill and it threw me off the board:
I have always been confused by this, I’m not 100% sure if this is total current draw from the battery or current for each ESC, @ackmaniac would you please chime in?
I just read your post, thanks for the input, well I feel I’m not alone here
47.4V total = 3.95V per cell
42.5V total = 3.54V per cell, under roughly 15A per cell
Look at the 0.75 Ah vertical line. The 0.2A red curve (which is basically resting voltage) is roughly at 3.95V. The 15A purple curve is at about 3.55V. Your results correspond almost perfectly with the published data
Depends on the amount of Vescs you entered in the app. When it is set to 2 then motor amps, battery amps and the consumption values (Wh, Ah) are doubled. At the point where you set the cursor in your image you are also not at the highest motor amps you have reached.
