Honestly I would like to fit the biggest pack I can in there. But I estimated it to be 10s3p but maybe u can put larger after u check the pictures.
A normal 60amp BMS I’m sure won’t fit in the thickness that I have to work with. It has to be a very small BMS in the front just used just for charging not discharging so it can be tiny and very little amps BMS.
Technically, my calculations say you can fit 20.4 cells per row, assuming the cell is 18.6mm wide. You have 324mm of space, divide that by 18.65, you get 20.4. So yea, you could fit 40 cells if you wanted, but yea, don’t know if theres a bms small enough out there to fit somewheres else in the board.
Do you know if those ESC’s do 12s?
You could do a 12s3p, get better power output and range than a 10s3p, with 36 cells. Leaves space for small bms
interesting. This is the halo board. Not sure what kind of chinese esc it uses. or how many volts it can handle. i know that it comes with a 10s battery.
If charge only bms, why not routing balancing cables to a 10 pin (or more…) connector and having bms hooked up to the charger externally. Would save you some space
