Looking to mount some Tq boards trucks on a la croix. Need a 30 degree wedge to do keep the 50 degree angle of the trucks.
Man, you spent the $$$ on the Lacroix. Get some Surfrodz trucks with adjustable baseplates.
Why can’t I like this comment more then once
honestly I’m going to try and keep the mbs trucks and run urethane, I have Tq board’s trucks laying around so I wana just try eem. Figured the riser would be somewhat cheap and easy way to try urethane before I buy some expensive bearings.
Ok, that makes more sense. Though, the surfrodz are fuggin sweet on the Lacroix with 107s.
The second I ordered a LaCroix I was like “how do I get urethane on here?” your build was inspiring as hell and drop dead gorgeous. These are the bearings I think I need to just buy and try https://www.vxb.com/Bearing-Sealed-12x22x5-Metric-p/kit20376.htm
Worse come to worse I just copy and paste your truck/mount set up, but I really really wana keep the MBS trucks.
Ypu could always Buy a second set and have them milled down to fit 10mm bearings.
It would probably be cheaper to buy surf rodz and adjustable risers. The only 30/35 degree risers that are available quickly and worth using are the OKP risers, and that’s only because I have a set but they cost a ton and I wanna get a ton out of them .
I’m also shopping for a set. Wanting to do a carvon LaCroix build.
oh man that would be sexy
