We’re making him his first basic electric longboard and he needs parts! The plan is a single wheel belt drive for campus cruising…maybe 25mph top speed? Located in US (Delaware)
What we bought:
36" oak longboard deck (no drop and slight curve) w/ grip tape
20x EBL 18650 3000mah (we think 10A cont. only 2500mah) [will do 10s2p]
Bms, motor and pulleys you can get them from @JLabs if he has them in stock and he is only in PA. Motor is more than what you lost but it is a 6374 which will work well for a single drive. You will want a 36v charger as that is 10s. Luna cycle sells a 36v 42v nominal and can charge 1amp-5amps
