Cool, i’ll contact you when i tried out the 192kv motors
What motors are recommended for these, kv?
What’s the difference in mini drive and heavy duty? I’m more interested in the mini due to the compact of it and looks. Do you know how these stand these https://www.e-toxx-shop.com/trampa/mini-direct-drive/mini-direct-drive-orange/#cc-m-product-9947425570 with helical gears?
Well mini drive is like street version which is not meant for heavy offroad and just normal riding It has 1:3 gear ratio so around 130-170kv is more than plenty.
Heavy duty is 1:5 and its most hardcore in everything, m5 bolts, 2.5 module gears, extra thicc aluminium and etc. So you could go full offorad with them or plug them in with high power motors like I am doing and kick the streets with wheelies and etc stuff For 1:5 you can go from 170kv-190kv motors There is also 1:4 option for higher speeds
Size wise Mini is just small, and SS is bit bigger but more massievier It’s like 1 cm wider than wheel hub so on 8" tires it’s perfect, I couldn’t get them hit anywhere in city even jumping curbs and etc Just only issue when wheeling I touching back of gear drive to the road but that’s like first world problems
Well helicals pros are more silent operation but it also has its own cons I am sticking to straight gears as its much easier to mesh and less troubles down the road
@Eboosted Hey!
I’ve seen your enclosures for these boards and they look amazing! What sizes do you have? Do you sell with battery or only enclosures?
Do you ship to EU?
Hey man! Yeah, I sell the enclosures and batteries.
Please visit the website at eboardsperu.com, let me know if you have any questions
I see you have enclosures for 12s4p and 12s8p. For a 12s5/6p the 12s8p Trampa HS11/HolyPro 35 DS would be the one to order then?
How much would you charge for a semi complete powerplant with a 12s5p with charging bms and port, no need for focbox/esc I’ve pre ordered a focbox unity. (or what battery packs do you offer?)
Thanks!
Pm sent! 10char
From your battery specs I get the impression you wanna build something like this. has >70km range. Its 12s10p (2x 6s5p) of 20700B - with DieBieMS.
That’s overkill for me I’d like 40 km range, so a 5P or 6P would be enough
Hi. What cons do helical gears have?
Hi. I am looking to run aps 80100 motors on 9" wheels on a Trampa mountain board. Is that possible with the drives stock setup or are modifications required? What’s the difference in mounting 8085 motors?
If you have motors the same style as in my picture then they are compatible but if you got the new APS 80100 motors they are not anymore 100mm length and they are much longer and they don’t fit
You will need to lathe down the axle of the motors to 10mm and also cut short as the 80100 motors has axles on both sides:
I don’t have any motors yet because I don’t know what will fit. Here it says the measurements are 80x100. So should be OK?
I specially mentioned because other customer bought the same motors and received complete different ones, the ones I uploaded picture so that’s why I am mentioning to you when you order ask for older design or etc.
How long are your motors. It’s hard to see on the picture. To me it looks like 105-110mm
