Essentially, the only other thing is I can still make a BT connection. Just figures that one out.
Is it one of the packs I sent you?
No, it’s a pack I had made specifically for a sound 39 and ended up using in the Evo and I supplied the BMS. Its not an issue with construction, it’s either a bad BMS or bad switch if I was home id find out, but alas it cannot be so .
Hi, I bought an anti spark switch on ebay, I had the non - latching button and put another button on the NC wire and it worked perfectly fine. So I set up the board and went for a ride and 800 meters in power started to cit out, then it came back and I continued to ride, but on my way home (2nd km) power completely cut off and something started to smell. When I rushed home and opened the enclosure I saw that the mosfets had melted a hole in shrink wrap…
I don’t know what should I do now. If I had done something wrong or if I should cool it somehow…
I had the wires soldered correctly but it just melted…
The button i got (model 6)
Dsnt rly specify but if its the original schematic, you need a latching switch. Else youll pull current thru semi open FETs resulting in what probably happened to you. Replace the FETs get a latching button.
