WTS: 12S BMS / Enclosure / Deck [EU/GER]
NEW STUFF:
1 x ABS Enclosure 500 X 145 X 25-30 40€ 1 x Kydex Enclosure 385 X 145 X 35 30€ 1 x 9060 DoubleKick Deck 55€ 1 x 12S BMS 5A charging current (BesTech)
75566445ad9efb5d520f533c5d907b3666c0053d_1_690x219 361a27c65d6bd7e40b8f5393fc956b3e73921746_1_690x364
please add pictures.
Prices? 10 characters
Is this the deck your looking for
sadly not, this is the evo deck:
http://landyachtz.com/media/catalog/product/cache/2/image/1800x/040ec09b1e35df139433887a97daa66f/e/v/evo-skate-and-explore-landyachtz-cruiser-board-longboard-downhill-freeride-drop-skateboard-04_1.jpg
Hi @Acidfie ! Maybe giving us the enclosure’s measurements would help you to sell it.
Inner dimensions are: 385-145-35 inside, fitting a 10S3P and BMS easily.
push/changes werde made
vesc still available
Hey @Acidfie I want your battery, enclosure and bms. Would this be ok on a flexy deck? And how much would you charge for postage to the UK? Thanks
Can we get a closeup of the VESCs please? two pics one for each pcb, just the pcb as clear as possible
4.12 hardware I think I see, presume they turn on and only give the drv error when trying to spin the motor?
yeah, i can take macro pic when i am at home.
they worked both without problems, although i fried the DRV while connecting the can bus. (GND Loop).
Hardware is 4.12.
I’m interested in the BMS. Do you have some specs or more details and manufacturer? Thanks!
I loaded up the pics again, they are big enough really, so don’t bother
May i ask how you fried them so i dont do the same thing?
VESC SOLD
10 char
Typical CAN-BUS ground loop, because i just used all 4 pins for connecting
Updated
10char
Do you have some more details on the 10s3p battery? What dimensions is it? How many cycles has it been through and does it come with a charger?
