Looking to get a pair of the new BN long motor mounts, just need to fund that endeavor and have a little cash spare for when shit goes wrong, I don’t skate as much as I used to so I don’t need all these extra toys, if you have questions lemme know and I will give you as much info as possible
Prices are SHIPPED in the US!
Single drive complete - $500
This board costs about $800 to make so this is a SIGNIFICANT saving Parts have from 30 to 300 miles on them, battery has less than 10 cycles. Board weights 13lbs and gets 12mi of range on flat ground with a 125lbs rider, top speed of 18mph with a 14T pulley and I have 15/16/18T pulleys for sale 10s charger included
Part | Name |
Motor | TorqueBoards 6355 motor |
Deck | “Skate Shread 36"” x 9.5"" bamboo blank deck with black griptape" |
ESC | Flipsky 4.12 ESC |
Trucks | 158mm 50° white/gold Caliber trucks |
Cells | Molicel P42A |
Remote | Flipsky VX1 |
Wheels | 76mm Ahmyo Akasha cut wheels |
Antispark | Flipsky 280A antispark |
Wheel pulley | Janux 34T kegel core bolt on pulley |
Enclosure | Meepo battery case for V3 |
Bearings | Zealous steel bearings |
BMS | DALY 10s 15a BMS |
Motor mount | Build Kit Boards single piece Caliber motor mount |
Motor pulley | TorqueBoards 14T steel pulley |
Bluetooth | Enertion HM-10 bluetooth |
Deck protectors | Dickyho X deck protectors |
Belt | 250mm HTD5m 12mm belt |
TB 44T kegel pulleys - $86
2x used TorqueBoards 44T bolt on kegel pulleys with black alloy steel bolts
