That was really helpful thank you!
wow thats good to here, how did yours go?
The 37v came form me contemplating if I should use the 245kv motor or the 149kv and i forgot to change it.
Well actually the parts are still arriving. Did you end up going with the 149kv or 245kv?
looks good, just change “Hub Teeth == 36” and “Pulley Teeth == 15”, that should to the trick
hmmmm…this feels awkward. thanks for the heads up. If the stats are going to be true even at 50% efficiency i will be one happy rider
I see… I have decided to stick with the 149 because Id rather have more torque, and according to all the calculators i have been using, my top speed is around 20mph and I am happy with that in addition the max voltage is 44 rather then 37
Cool. I got the 149kv too. That top speed is pretty good. I’ll have to eventually go from 6s to 12s.
can u link the site you used
