Hi there… Am a bit confused on what the XT90S connectors do, and how to use them properly.
I own an off-the-shelf Trampa 2019 pro board. I understand the XT90S’s have a resistor in them to help prevent a spark ocurring, but I’ve had a few issues where they do ‘pop’ as I’m connecting the loop keys. Does this mean they should be instantly replaced? There is a small amount of black charring inside the connector, but nothing overly concerning. Are they also meant to act as a fuse?
Also, when it comes to connecting the loop keys to the board, is it best practise to connect the end with the resistor into the board first, or the other end?
Thanks.
