Hi,
I want to order 5M 11mm 16T motor pulley. Will it run ok with 10mm belt and 10mm wheel pulley?
Thanks
Hi,
Thanks
Yes
Wheel pulley will be slightly bigger but 1mm is hardly gonna change anything
Haha thanks
I knew it will fit. My concern is that it will slip.
They always add a little extra, usually 1mm to the width of the pulley simply to ensure a good fit without any side rubbing which would reduce efficiency.
Yup, figured that out.
switched to 15mm but thanks
