Hello. First, I would like to get one thing clear. This topic may seem like I should not have created a new one, but I feel like there is a lot of conflicting information, so I feel like their is no clear answer.
I am planning a belt driven build, with this battery:
I was wondering if anyone knew of any good bms systems, and chargers/charging ports which would be compatible, links would be nice. Thank you
Well for charging the 30A is more than enough. I am not sure what charge port you want since the bms does not come with any. You will have to connect it up yourself based on the wiring diagram in the description of the BMS. So you will have to solder your own connectors.
And yes you can, you will connect the battery indicator in parallel with your battery ideally after your switch so that you dont have it on all the time draining your battery.
