Yes but I’m pretty sure it does not make any coffee or something else…no good haha
Haha, well i haven.t tried yet. I mean if i try to charge from 30V to full the charger is getting pretty hot so i might be able to warm some hot chocolate
and bacon too
man, I have ordered some 42v too, now there is a 42v or 50v selection in that product page <3
After downloading app and registration I got 10% off coupon - score !
@MontPierre
I must say, that this is one nice built PSU in alu chassis
It has a fan though, but it dosn´t run when powering up the psu, so maybe it is temp. controlled ?
Even the instructions is well made, and not the typical “chinglish” language.
Comes with two extra fuses as well.
It has two LED`s. One for power, and one for chraging status. Nice
Cool! Thanks man! Mine got shipped this morning. So cutoff voltage is 42V? My bms has same cut off so that’s fine
Just FYI, there are bunch of chargers exactly like that one from Banggood @Silverline mentioned.
And not only for 10S. Just search AliExpress, for example “cutoff_voltage charger”. I was looking for 8S therefore “33.6V charger”. You can get different charging current variants as well… 3A, 4A, 5A, 7A.
This seller has a bunch, browse through his store…
Yes, if you look at the instruction picture i have posted, you can se all the different models
Do you know how the fan is working BTW: ?
Yes, the fan is temperature controlled. It turns on and off multiple times during charging. Doesn’t yours? If not, think about contacting the seller about this.
I have not tried the Charger yet. Need to build my board first
I’m using a 10S 4A charger from alliexpress and it works great. Charges my 10S 5,2Ah pack in 1,5h.
Will u put link to charger up
IWell Its only 3A. Not sure how much your batteries can take but I have this one
36V 37V 42V 45V 5A Battery Charger For 10s 10x 3.6V/3.7V Lithium Li-ion Battery
Works very well and charges quickly. Had to charge plug to match my socket on the board - 2 minutes soldering job
Charges my lipos 10s 8000mah in an hour from approx 35-36 V
https://m.aliexpress.com/s/item/32760909127.html?spm=a2g0n.search-cache.0.0.604ef82dLOdrKQ
A quick search turned this up. No idea if it is any good.
I thought 3A might be good since it’s more then 2A so charges quicker but less then 4A so longer life.
Yeah, it depends on how many C you can charge your batteries with. Mine don’t get warm at all during charge so I know I’m fine, I’m not abusing mine
i got my 4a laptop brick style 170w charger from germany heres a link https://www.ebay.co.uk/itm/Modiary-Li-Ion-Charger-42V-36V-Batteries-eBike-DC-Round-Plug-4A-170-Watt/263264057628?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m2749.l2649
Will I be abusing my 10s4p 30q battery when I charge it with 5a?! I thought the recommended charging current was 1.5A per battery times 4p so 6a?
