Just wondering if anyone has used one of these BMS’s before? Building a 12s3p pack from samsung 30Q cells.
Yes, works well for me. Make sure you bypass discharge.
How do you go about doing the bypass?
Use the bms as intended only for charging. Two connections to the battery output
