I spend the last few days learning about building custom batteries. Would this be a correct layout of the 12s2p? I am mostly confused about the BMS and the charging port wires
I appreciate all the feedback and feel good about being part of this community!
Definitely avoid copper braid. I would also recommend against soldering directly to batteries if you can avoid it. Look for cells that already have nickel tabs spot welded to the ends and you can safely solder wires to those. For your build I’d recommend at least 10 gauge wire if not 8.
Not sure what fuse to recommend. I’m fairly new to ESK8. Been in the Rc hobby for over 10 years but we dont use fuses when charging. Just hobby grade balance chargers.
