It is a 50.4V 1.5A charger. I am a bit new to the whole charger picking and so as far as I understand the only difference should be that it would charge slower right?
Any additional tips, knowledge will be greatly apreciaced.
thank you very much for the reply. Unfortunately I found out the vendor is trash the hard way XD. I absolutely know what you mean by chape/good/fast, but at this point I would be okey with buying a little more expensive one . Do you happen to know of any more pricy but good and fast option??¿??
also, how is it with the amps. A lot of ppl keep saying 6A is too much but other say its fine, I understand it depends on the cells but most ppl use samsung 30q right??¿??
Ive build a 12S4P battery made out pf samsung 18650-30Q batteries (3000mAh capable of 15A discharge, rated for 4A charge). Im was just wondering if you know of any vendor in the EU who might sell 50.4V 2-4A battery charger. I understand that fast+good= not cheap. I was trying to find anything aroun 70€ but all I found was aliexpress/alibaba which take long to get here so I was just wondering if you know of any other options??¿??
