Plasti dip spray it matte black instead. It will still look mostly the same, but will protect the actual finish somewhat and can be peeled off and reapplied when it gets messed up.
Or some strategically placed stickers to cover the gash?
Lol that’s still a Ferrari! Print or convert a car key case so it doesn’t look anymore like a simple loop key BTW can’t tell how but because of you I got a feeling of why (not a scientific why) high voltage helps a lot for pack acceleration, aside from top end speed. Now I’m tempted to ditch 8S and directly try 12S… Heh I already got that fancy 8S 6A charger! Not reasonable…
Lol. Don’t mind me. Just let me be all whiny and butthurt that I insta-dicked it straight off a little curb
8 to 12 would be a massive jump
Literally the first few hundred feet of it’s maiden
Update:
Board is an absolute dream! I have probably 5-10miles on the board so far and my voltage is now only at 50.4v lol… 13S is hilariously awesome. I knew I would get more miles out of it by upping voltage, but not nearly THIS much. I can’t wait to get my metr bluetooth module so I can see just how few amps I’m pulling when compared to 12S.
Riding in FOC is very nice and I have grown to actually like the silent operation (hated it at first). Noticeably more smooth when compared to BLDC.
20mm wide belts are a damn dream. I can run them with super loose belt tension and still have perfect engagement with no skipping due to the extra width. I can free coast forever almost like what I assume a hub motor would feel like.
The one thing I don’t like about FOC is the jolt it gives when decelerating from .5mph to a dead stop (almost like the motor is locking up right at the very end). Apparently this is just an inherent problem with FOC and can’t be allevaited. Doesn’t make sense why it could start up amazingly smooth but not brake amazingly smooth… but what do I know haha…
I’ll keep you guys updated. Future plans might be to add pushin cushion, not that it needs it but it would make it even more comfy.
Oh yeah and lastly thank GOD I didn’t go 4wd like my initial plan. This thing is capable of lifting the front end off the ground if you aren’t laying down on it, and weighs ton even as is. A near 40 pound board would have been a big mistake. Maybe if you are going up 60 degree hills you’d need it, or weigh 300 pounds… but I’m not heckingneither of those boxes. This is exactly what I want an electric skateboard.
thanks for your detailled feeback mate !! We cant wait for your bt module too
This is the first board I’ve owned that I’ve changed out the bushings. First was a boosted board which I didn’t touch and the second was a trampa so it had springs. I’m currently running blood orange double barrels 89a out back and 86a up front.
I just took a look at this chart and it seems I need a stiffer bushing. I swing between 195-200lbs.
What do you guys think? I would definitely consider the evo a stiff deck…
Hey I know we talked but I’ll put it here
Your currently on Blood orange double barrel 89a/89a rear And blood orange barrel 89a boardside/ 86a roadside
As you like the way it feels/turns but want a better centering. Think you should switch board side bushings from 89a barrels to 89a wedges to increase rebound and centering.
I’m sure others opinions will help though
PS the Muir skate duro chart is universal. Blood Orange is similar to Riptide APS bushings(not WFB)
How have you been going with wedges? Have you experimented?
Currently using boltzen 12 degree. 70/30 was a crazy as I spend most time cruising around the 15-25mph range.
How’s your board holding up with 13s? What kind of range are you getting on this beast? Debating whether I should go the 13s route when I start my evo build…thanks man
I’m sure he’ll respond. But he’s getting around 26-30 miles and it’s been holding up great. Mine(basically the twin brother) is almost done.
Heere’s a log from the other day.
Yeah it has been working flawlessly. The extra cell keeps battery amps wayyyy down.
I haven’t seen over 40A ever and this setup is geared pretty tall and I’m 200lbs (setup will do 45mph easy).
Even at 100A motor setting I’m not getting any of the abs fault codes I was getting with my 12s trampa build before this one. I’m sure it’s do to the upped voltage which in turn means less amps pulled.
I will never build anything 12s ever again. 13s is the way forward for sure.
@alhow for range I would say 25+ for cruising and 15+ for beating the hell out of it.
does 13s give higher top speed? I mean You could wait till voltage drops to 12s value but Then whats the point?
This build goes 45mph … Find a other belt drive that goes that fast @Blitz
Plus efficiency is out the wazoo
OF COURSE IT DOES!!!
Higher top speed, faster acceleration, better braking more efficient.
Other than that it’s completely pointless tho
Furthermore it was wasn’t even intentionally geared for speed. I tried to keep a really reasonable to have insane acceleration and not do much over 30mph to keep my ass out of he hospital. Well I underestimated what an extra cell does. It accelerates faster than I can even stay on it and it does 45mph easy. Best of both worlds. Slightly taller gears and this thing would be in the 50’a no problem. Not a chance I’m testing that shit out though hah.
Shit im running 9s This is so cool Ima read this whole topic
Thanks For explaining!
Is there a limit for how much series these 63mm motors can handle?
There is a limit but not one will ever reach mostly these motors "ratings " are from vesc , I don’t there has bin anyone in this forum that has hooked a "10s motor " and burned it because they hooked it up to a 12s battery more like 10s motor is because of the kV and it will reach the erpm limit on the vesc
