looking for on 14 tooth steel motor pulley and 2 15 tooth steel motor pulleys
Bore size?
Belt width ?
Keyway? 3mm?
aluminum is ok?
motors shaft is 8mm, 12mm belt so 12mm ideally, looking for steel tbh keyway preferably ya
I need 2 15t with keyway if someone has some Bore size 8mm 15mm belt
https://eskating.eu/product/custom-htd-5m-12-to-20-teeth-steel-motor-pulley-in-91215-width-2x/
You can get any configuration you want, they are great quality and @fottaz ships worldwide quickly!
thanks man perfect
Eskating man
