And your auto correct doesn’t even know what a “dongle” is. Thinks you mean “single”. Lol
Yeah, it thinks I talk about ducks a lot too
I am happy to announce a partnership with @Martinsp and http://electricskateboard.repair. This will make these modules accessible and quicker to obtain for customers outside of the US as he is based in Slovakia. http://electricskateboard.repair/index.php?id_product=30&controller=product Yay for non-US customers! @FredrikHems
Also, orders are back up on my site (made and owned by @thisguyhere). Will be getting my own site up and running sometime soonish : http://esk8life.com/plug-n-play-vesc-bluetooth-module
cmon people. yknow you want it
ok I need to get rid of these quick…
price dropped to $15! click here
shipping only $3. last run ever so its now or never.
All done? Why no more?
different vendor bought in extreme bulk…
you know the rest
a little bit annoying but i probably should’ve seen it coming, at this point just trying to make some of my money back
Gotcha …
Okay, I’m deffinetly interested in picking up a couple of these modules. Just walk me through it, so I get this module, plug it into my VESC which is running standard 2.18 firmware, open the eSkate VESC app on my phone, and then connect to both vescs at once and change the settings, monitor them, etc. Or can I only connect to one VESC at a time? And am I missing any steps?
- Plug in to UART port
- Open BLDC tool
- In the PPM tab, change to “PPM and UART”
- Connect to your phone
- Open app
- Hura! You’re done!
pretty sure for dual vesc monitoring you need 2. I personally only use 1, stats on the 2 vescs should be near identical.
oh yea, can only connect to 1 vesc at once.
order today, ship tomorrow.
Awesome, I’m likely be ordering 2 shortly then. I’m assuming I’d need one for each VESC in order to change the mode on them, as I’m running split ppm, not canbus
heads up. as of right now, you can only change basic settings on IOS apps. if you’ve got android, your all set for changing settings. but yeh, need 2 if using split ppm
What do you mean by basic settings? Basically what I’m looking to do is monitor the vesc, and change modes, IE: change batt max, motor max, and start-up boost, that’s about it
Oh and follow up question, can i use these bluetooth modules to connect to BLDC tool on my computer?
Can I create modes and toggle between those or would I have to change individual settings every time?
I may be wrong but I think you can do that with @Ackmaniac’s app. changing these settings takes less than 10 seconds and works flawlessly every time.
You’re definitely right @GrecoMan! @pennyboard Use @Ackmaniac’s firmware/app and you can do everything you want to do.
Okay, and installing his firmware is simple and everything? I just have a reliable board set-up now and I’m of the mindset that if it’s not broke, don’t fix it, so I want to be careful not so screw it up lol
yea super simple.
- Download the FW file
- Open BLDC-Tool and click the “Firmware” tab at the top
- Click “choose”
- Find the FW file and select it
- Choose the 4.12 file (SUPER IMPORTANT)
- Click upload
