Hi, im a uni product design student working on a project for my final, i need help comfirming my parts list will work together before i start buying. Here are the parts list:
Safe discharge rate if a lipo is defined as the C rating times the ampacity in Ah
3Ah * 20C continuous is 60A continuous
3Ah * 30C burst is 90A burst
The motors are rated for about 15A each but may draw slightly more if you are maxing the throttle up hill, the BMS could suddenly cut power so be careful
In all likelihood it will not pull more than 10A and you should be fine, my hubs are comperable and pull 19A max speed uphills
The ESC is complete crap, it is only designed for 6s or 7s and a max amp rating of 12A which is way to small
Try this if you want cheap and simple, it’s not spectacular quality but I run a dual hub budget board with it and it’s very nice to use
I don’t know what link to give you because that sweet USA privilege but make sure the ESC is rated for 10s specifically and at least 30A or about 600W per motor
I just remembered that the esc I linked may actually support 10s. So, a while back, I read that in the reviews sections, customers reported that desoldering the connection between 6s and 7s points allows the esc to support 10s.
For some reason my hub motors are not working. Shouldnt there be sound coming from the hub motors? There is no sign of power coming from them. Though when esc is off and i spin one of the hub motor wheels it automatically powers on the esc. can anyone help me please? image below shows wiring
NEVER MIND!
Got it work by disconnecting the power and reconnecting it to ESC again. There were sparks when connecting battery to ESC the first time, and also the second too when reconnecting, but it worked arfterwards somehow.
