@treenutter @trbt555
Yes, the signal varies 5-10% when keeping it steady. Should changing the deadband show in the displayed bar(in BLDC-tool), because it keeps fluttering around 5-10% no matter what I set the deadband to.
I have tried setting the pulse width to the actual values. Problem is say that the highest and lowest value is fluctuating between (for example) 1.90 and 1.98 (or whatever 5-10% is). Keeping a steady throttle results in 5-10% fluctuation in motor power.
Max pulsewitdth with particular trim setting fluctuates between ~1.820 and ~1.880 very quickly.
“You can increase the deadband in the ppm app tab to account for signal variation around neutral.”
Problem is it fluctuates at 60%, at 22%, at 88%, not just around neutral. Increasing the deadband did help with finding a stable neutral state but the throttle is not smooth.
