think my antenna got loose on my 2.4Ghz mini remote receiver, so I tried to open the enclosure to re-solder it. sadly its well sealed, so I had to break it open and while doing that I damaged the SMD capacitor (see picture). can anyone tell what kind of cap it is? there is nothing printed on it, dimension seems to be 3.2 x 1.6mm (just about, cant tell exactly really).
just looks like a decoupling cap (on gnd and 5V rail), 2.2uf 16V should be good (0805 size???)
it will probably work without it… but also good to have it, you have a tantalum cap that’s there for the lower frequencies, that one would take care of the higher frequencies
hm, I have no clue about these things - all I can do is hold a soldering iron and do some minor soldering work. from the size table this seems to be a 1206 size apparantly. is bigger = better for low passing? should I look for anything above 5V and large capacity?
