Short term lurker here!
Post number one, could not find more specifics around this product using the search function.
Turning my longboard into an Esk8 on a bit of a budget.
This particular component looks ok for my needs:
Max Speed: 20MPH
Range: 10 Miles
Rider Weight: 180 pounds
Terrain: smooth concrete/brick with slight hills
Occasional weekend rider
Single Motor Belt Driven
My primary question is around the max amp rating of the ESC. On-site specs indicate between 10 and 15 amps max typically. However if I go 6s this limits me in theory to 350w motorā¦ (350w/24v) Surely this is not the case? Does anyone have experience using these? What have I missed?
Thank you for the quick response. Even at 36 volts (limit with this esc) I will not achieve my target of 20MPH
I forgot to mention that planned build incorporates motor mount/belt drive.
I read a previous reply where someone suggested using RC Car/Truck ESC from 1/8 or 1/5 scale units.
Possibly like the below? I will spend some more time reading up on the ESC forum.
Agreed, reading through so many posts working from my own limited experience it seems this is a component I donāt working out of budget for.
I will read up a bit more later this evening, for now a quick search returns this unit which would allow for 1800w motor running a 36v system.
I am aware this is not a VESC:) Any suggestions would be welcome, I have a Flipsky FS-GT2 remote
I have a 36v board that is geared to 26mph on 5065 200kv racerstars.
I have one of those āesc substitutesā that I never used, if you want something cheap and fast. These are good for budget builds since it includes the remote and power switch, things youāll have to buy with any vesc based esc. Pretty much every prebuilt board runs this esc, and setup is plug and play, no vesctool setup headaches. PM if youāre interested
I have no doubt that 36v can get you past 20mph but seems theoretically unlikely if you canāt exceed a 14amp draw. (ESC Substitute)
I guess what Iām wanting to hear is someone say, āI run a 1500w motor on a 36v system on my esc substitute all day long and no issuesā. And then include a link:)
I dont know where it was, but looking for info came accross a guys post that did some tests. He changed a certain resistor with a higher value. And replaced the caps for 100v types. And did some tests with different batteries. I think he even tried 16sā¦ the board beeped like mad but still it worked making the 36v rated hubs spin like mad. But that being said he didnt test the board under load.
