Mad hubs form
Mad Fury form (you need to fill it up both if you want the DD and do not have the motor already). 200 Euro 2WD DD kit, only 10 beta units.
Link to post about MAD Fury DD Kit: 2nd Round MAD hubs Group Buy + MAD Fury Direct Drive Conversion Kit [EU/US]_Completed - #120 by rey8801 - Group Buys - Electric Skateboard Builders Forum | Learn How to Build your own E-board
Hello guys! After the first GB since few people asked me about it, would you be interested in another fast GB to get the MAD hubs? I thought, better to do it now before summer comes, so you can have the motors in few weeks. After I tried both the options I suggest the 75Kv version over the 130Kv, but they are both available. Few links for you to get catch up
Mad Fury direct drive kit
-Would you be interested in a pair of MAD hubs? 10 sets should be enough to make it worth it and be able to get them for 170 Euro.
- Yes, I want reserved a set
- No, I am not interested at the moment
-Would you want me to include the MAD Fury conversion kit to direct drive as an option? I should be able to provide it for about 200 Euro, depends how many people want it.
- Yes
- No
I am really happy with the hubs as direct drive, but if I make it available, I will do that with a slightly different design where you have a strong 12mm axle running across the whole drive. As it is now is fine for me but better to make stronger anyway. Also in this case you will able to come back to the original hub motor configuration. I don’t have the final price for them but my target is to get them available for about 200 Euro (including customised truck with 12mm steel axle and motor Pulley of your choice Kegel or ABEC; if the price allows also the motor can in metal otherwise I will share the STL file and you can print them. They get bit up anyway). Then you can assemble your direct drive! I think it’s pretty cool. I was really happy when I did mine.
Let me know!
Little summary…
Prices
2 Hubs (sleeves included) 180 Euro
Predrilled Paris clone truck 10 Euro
Spare PU sleeves 10 Euro each (You need 2 for a dual set)
MAD fury conversion kit 200 Euro (on top of the motors, only 10 sets)
Shipping to EU from 15 to 30 Euro depends where you live (I am in Belgium). To US 35 Euro. Possibility to come and pick it up. You would do me a favour!
Hubs weight
The stator size, not bad!
The current direct drive MAD Fury
12s 97mm wheels. With 90mm I reached 54Kmh instant speed, not kept full throttle for long.
How the direct drive will be. I can also make a more designed central hanger, but the cost of manufacturing will increase. It’s based on you!
Here two picture so that you can see how the final product would be. Simple to keep lower the cost, but still sick to me
97mm wheels
100mm BOA
110mm wheels to go over cars
Probably you have seen it already, but in case you do not know how it sounds. Unfortunately I only have bench test video.
