So it will be powerful, but we should run it with a bit lower Amps so?
(but on the Mf it should maybe be running at the same Amps than the 75kV like it is cooler in DD configuration ?) it that supposed to be right ?
I would love to try with 60kV, but they donāt make a new mold with 100mm sleeves ?.. As I donāt know when I will have money for the Mf conversion (that I would love to run with 107FW), and I will surely ride this hub under 10s with 90mm wheel for a little (for me) cruiser during until the end of summer ā¦ the 75kv seems to be a nice option middle option, and after all your good and cool feedback, I now 100% confident in you man !
In the other hand, I know I would love to try this 60kV with Bgm ^^ (if I put the efficiency at 80% with 145mm AT wheels, I got around 55kmh ā¦ But it should be AWD for fun I guess ).
Thanks for your work Alessio !
I stay with the original Mad Hub motors 75kV (without trucks)
PS : Nice render! I like the ground clearance here !!
Just got popoca as well Really nice wheels.
To me the 60Kv is only for who want to ride big wheels otherwise 75Kv, I tested and itās really strong. The setting I would keep the same one.
@ervinelin hi man. Do you perhasp have bergmeister cad model and pulley? I think you mentioned not long time ago. Since now a 60Kv version is available maybe would be good with them. I am doing the pullley starting from a STL file but I hate to work with it. If you would have a step or igs or whatever is not STL would be great. Thanks!
ah ok then perfect the white one seems perfect to mount it for the Mad Fury. I will send you the finish file to test it on bgm wheels afterwardsā¦
Ah I see, the space in the model is for the valve?
Unfortunately the Ackmaniacās app doesnāt work properly with the Unity otherwise I would have already made some rding video with telemetry to show what I mean. For now I can only use classic phone app.
