[SOLD] Two FSESCs that I added connectors to but did not ever use on a board ($85 apiece or $150 for both)
[SOLD] Same with the anti-spark switch ($20)
[SOLD] The belts are not used ($2 apiece)
Two motors have not been used but the shaft has been ground flat on a portion to help with the set screw grip. One has been used but works just fine. All come with original box and parts. ($60 apiece)
Various unused pulleys, I need to look back and see teeth counts (make an offer)
Looks like I can send it in a small USPS Flat Rate box for $7.65. So I could do $25 including shipping and send it out today or tomorrow on my lunch break. What payment method do you prefer?
Are you sure it sent through? I checked and my request has disappeared and I have no payments to me showing up in my transaction history in the past few weeks.
Okay I will log in on my desktop when I get back from work and see if I can find the issue there because it’s not showing up anywhere on mobile. I will send you the tracking number when I get it to the post office, I’ve already got the box and stuff.
Hi, I’ve had that PayPal account for years and sent and received money through it, I don’t know why it was being weird and making me reconfirm my email and such. Anyways, the package is ready and I will drop it off at the post office. Here is the tracking # Tracking number: 9405528206335339182666
Hi I just got the anti spark switch today. I plugged it in to my fsesc6.6
And it doesn’t appear to be working it’ll Flash my VESC on and off if I hold the button in
But that is it. Also there is an extra blue wire and none of my other flipsky switches have this wire. What is this wire for and where does it get connected to could that be part of the reason why it’s not working? I’ve been on flipskys website and they don’t seem to have any wiring diagram that includes that wire.
Also that’s which is not new it’s all dirty inside you can see it just from looking from outside anyway I found out what that wire is that’s the motor detection cable or doesn’t matter the switch doesn’t work anyway.
I bought the switch years ago and I guess they stopped making them with the motor detection wire sense then. I never put it on a board and road it around I only ever bench tested it when I was gonna make a new build a while ago and never got around to it. Any dirt/dust your seeing would be from it sitting in my garage. It worked then, have you tried a different pack voltage? I remember reading somewhere when I got it that it could be finicky about certain series combinations.
I tried it with my 12s battery from my other board that also has a flipsky anti-spark switch. The enhanced version that is designed for less amps then this one.
This version is supposed to handle up to 13s. I tried it with a 6s and it will work but i won’t work with a 12s
so it is defective. Basically it is useless for any of my esk8 set ups as I don’t use 6s except in series lol.
