I have finally completed my first eboard. I’ve been riding around and testing for the last couple of days. I will take it for a proper test tomorrow and ride for a few kilometres. The total price of the board comes to around $300 AUD. Would there be any intrest in me starting a build thread with all the parts listed?
Thanks to everyone on here and all the help you guys have given me
This is a build I did for a guy at work five or so months ago. Marine150a ESC 2500kva inrunner gear drive, 8:1 ratio on 70 mm wheel, 4s. Under 300.00 usd. Still going strong. 26 mph and just did 7 mile santa Clarita run and kept up fine with his 200 lb of man on it. He decided to upgrade ESC to 200a 1/5 trackstar for better brakes after the Clarita run.
We were trying for bare bones cheap cheap cheap. Goolrc 2650kv 1/8 inrunner $28.00 (the 2000kv is a better fit). flycolor 150a esc waterproof 38.00 (very hearty esc 10ga wire and does not overheat, no brakes) gt2b radio $27.00. multistar 4s 10000mah $65.00 b6ac charger. $15.50 hot racing pinion 5mm 9t 32p $10.00 Robinson racing spur 72t 32p $15.50 used longboard 50.00. hand fabricated motor mount misc hardware $35.00. Total $284.00 setup still working well and yes the gear drive works, use 70mm wheels. I highly recommend getting an ESC with brakes.
So for everyone asking for me to post a build thread, I will next week sometime. At the moment I’m waiting for a new esc because the one I was using blew up the other day (it was a $12 40 amp heli esc for testing). I am ordering a 120amp X car beast esc tonight. Can’t wait to get riding again soon. The build is now around $350 AUD or $260 USD which is still cheap as chips
I’m riding the x-car beast 150 on a 6s system without any problems. The only reason I would like to have another ESC it vesc is that it is quiet big. Instead of 2.5 cm my housing needs to to have a height of around 5 cm. Other than this I have no complaints.
Ok thanks. It’s nice to know that they are good for eboards. That’s the same problem I have, as the enclosure must be quite tall. I think I will just cut a hole in the top of the enclosure though so that it will also get good air flow to the esc. The other thing is I might be able to take the esc out of its original case and put it in a smaller slimmer one.
