I guess they`re just standard 8" pneumatics?
True dat. I didnāt realize that pneumatics are so damn huge.
Its a mountain board. So the wheels are very big 8inch So nothing happend right? Im a little bit confused with all of that data.
at 0.021ohm, the esc limits the current, not the motor⦠so at 12S you can get 300a.
simply shorting the motor with 48v (not advised) gives:
48v/0.021ohm=2285.71a
2285.71a * 48v=109714.28w
the job of the esc is to limit the current below 2285.71a (in this case to 300a).
for motor heating that works out to: 300a * 300a * 0.021ohm= 1890w motor heating @ 300a
since the kv is 149kv, torque at 300a motor current works out to: 300a * 0.064nm/a (kt-torque per amp)= 19.2 newton meters.
I didnt quite understand that, but there is no way you`ll get 19.2 Nm of torque directly from a 6374 motorā¦
Disregard the over educated⦠Your motor will not pull over itās designed amp if you donāt overload it⦠gear it properly so it operates in itās load window and you will be fine. A 300a ESC on a 70a motor is a good combo and a great safety factor window for your power delivery systemā¦
Thanks a lot!! God bless you
