anyone have any stl files for gears or motor mounts?
all the files on here seem to be broken and the pictures too on most posts
pictures are slowly linking back up after a major server upgrade, should be good in a day or so,.
check this link
May be the Laser welding machine can do a help. In the processing process, high-energy laser pulses find application in locally heating the material in a small area. The energy of the laser radiation diffuses into the material through thermal conduction. And then the melted material will form a specific molten pool.
No pressure is required, but inertness is required with gas or filler metal to prevent oxidation of the molten pool. Laser welding has many advantages such as a high aspect ratio, small weld width, small heat-affected zone, small deformation, fast welding speed, smooth and beautiful weld, no or simple treatment after welding, high weld quality, no porosity, small focusing spot, high positioning accuracy, and high automation.
