Here we go… changes on thingiverse to ptowncruisers design.
My favorite change is the 3x zealous bearings in the pulley hubs, works great to reduce play with the pulley sticking out so far.
I bought a set of these a while back I’ll need to check but I think at the time they came with different hard pressed high resistant
bearings and the wrong diameter. I’ll have to recheck. Been trying to sell them to someone with more free time in Europe.
I bought these because I was too lazy to print the hub…
They fit TB 218mm trucks but the bearings are pressed in and I have no idea if they can be easily replaced.
I am also designing a geared drive for it.
Here’s the adapter that is meant to interface with the hub.
You would need a bearing puller, Easy peasy. I have changed motor bearing that way.
I went a non standard approach, took some measurements and came up with this. Will print it in a day or two.
What do you guys think? @ervinelin @Maxid @skatardude10 ? Should I change anything before I print it?
I think the rim will burst once you inflate the tire. The reason for my screws being so far away from the circle center is that they are supposed to eat the forces on the rim wall. In your design there is nothing helping the plastic to stay in place and the material is not up to hold several bars of pressure
But those are metal rims, right? Hes just printing the pulley and pulley adapter. I think it looks good to go.
Right! The rims are already metal. The one that I got from ali-express.
ah got it - I thought you wanted to 3D print the rim
Can’t see why it won’t work… But your pulley has not many teeth? I was aiming for something like 60T but the size of that would make it larger than the rim resulting in potential hitting the tyre when it flexes.
files are here: https://drive.google.com/drive/folders/14AF8h_PFzBTdH6JRkKynJ70I3WzezC0N
You can modify the design to have whatever width and how many ever teeth. I selected 50 because 42 would have caused the countersink for M6 bolt head to be very close to the teeth. You can easily go to 60 teeth, just change it in the solidworks equation.
Hi guys, I saw some great projects here. I’m strongly considering makeing 3d printed wheels for my future build. I’m worried tho. Using PETG for that purpose with its hydroscopic properties give me a doubts. Could you share your experience with me?
Well it handles 30mph (32/33 was my top speed) pretty well and I put arpund 40 miles on my set before my esc died
Got maybe 30-40mi on mine as well, no signs of wear. Unsure top speed as the trucks need new bushings to be safe. I don’t think they will be wearing out anytime soon. Printed in standard ABS. Some rings printed in PLA cause I ran out of ABS. Seems fine for now.
Hi guys, anyone knows an alternative tire that can be used? Feels like the 6x2 from AliExpress have very high rolling resistance…
all pneumatics do - turn up the pressure to increase efficiency. They can be bought as solid tires now - should be super heavy though and I am not sure if it actually makes a difference for rolling resistance.
Already at max rated pressure of 70psi
I’ve got 250-300 miles on my PETG hubs, and they are holding up great, no signs of wear or cracking really… Although I did have to print the rims for the hubs out of nylon because the PETG holding the side walls was not enough and it started cracking.
what do you mean with hub? the pulley?
I will printed this hub for 6x2 tire. I have ABS at home but I was thinking about to order PC filament. Pc is much more stronger. But Is it good choise? Did anyone try print this hubs with anything else than ABS and PLA? Wich filamet will be the best?
Will Psychotiller’s wheels work on this hub? https://psychotiller.com/collections/wheels/products/sixshooter-6-x-2-replacement-tires-and-tubes
