Cool cool. Have you had good luck printing abs without an enclosure? I’ve been sticking with PLA and PETG. Also a tip, you can add 2 more linear bearings to the table slide that gets rid of some wobbles. I’m currently designing a new carriage for a Bowden extruder and add 3 6mm rails and linear bearings to the y and z axis. I can share all the files if you are interested (will be done in within a week).
Don’t use the anti Z wobble!
I’ve owned an A8 for a few years and I can say that this doesn’t help the printer.
The guide rods are enough to keep the x axis aligned, restricting the threads will cause the white X-carriage mounts to bind up on the threads which will give you more X/Z issues.
Also, those chains are just there for aesthetics right? I tried them out and they only caused issues. After a day I ripped them off lol
jep, keep the anti z-wobble away fromt he printer. if you have wobble there, get new rods. the anti wobble thingies will only put strain on the motors and those rods are actualy designed to have space up there.
that gopro case doesnt look to good btw. you shouldnt be able to see those lines. that be could be to high temperature (looks like it), bad calibration (overextrusion, wrong values for the steppers) or loose belts (head doesnt stops where it should stop)
a few tips:
do not put the spool on top of your printer. ther acrylic frame will only wobble more and further decrease your quality.
do temperature calibration runs for each new spool you use. every spool is different, even if it comes from the same company
Just finished my whole ANET A8 upgrade. Extra 6mm rails and bearings to the y and z axis, New bowden hot end, nylon belts instead of the steel ones it comes with. I can provide files to anyone interested. better
