So @3DServisas (my father) decided that he wants a Trampa board. As @3DServisas is busy working I will be maintaining this project log for him. So this project log will be I think the cleanest project I have ever seen as almost all components will be built from scratch.
Some key features:
Trampa 35º Holy Pro Deck
Trampa Vertigo Trucks
FatBoy SS 1:5 Gear Drive
9"/8" Wheels with FatBoy Solid Wheel Hubs
12S 10P 30Q 30Ah 150A Battery pack with custom CNC machined enclosure integrated BMS, FatBoy Mini Sparky Switch, Battery Gauge and etc
Smart Rear lights, RGB string lights, Front Lights
2 x Enertion FocBox with custom waterproof enclosure
Enertion Nano-X
I will be posting all the pictures I receive for this build here.
So some Trampa parts arrived today:
Gear Drive on the hanger
Battery case for 12S 10P 30Q still in making
Still waiting APS to have 8085 motors back in stock so at the moment will be using 6374.
It’s not compression, its just enclosure, everything will be welded in old school way Just to make sure that cells stays in place are isolated and water proof About availability I don’t really yet know
Well plastic is like butter to cut compared to aluminum. Yes, black piece is gasket for the lid I don’t think it will be transparent maybe even from aluminum for mounting all regulators and as
He has done some hardcore ATV with polaris through the mud and forest and etc so I think this will be fun too Well I will be trying to fit 80100 on mine… Mine is bit on practical side I made from available parts This project probably include everything custom made so I think this would better than production level product
Don’t have any doubt on that score. Definitely better than anything production. How are you getting the focboxes to handle that battery? Would have thought 6 at the least or even a couple of arcs?
Ahh now I understood VESC6 uses same mosfets as focbox so not much different power capabilities About the arc I don’t really know yet anything plus its bit too expensive…
Also on my focboxes I am running ±90A Bat and it holds up well ESK8 doesnt see much constant loads so you get those high currents for several seconds max
Well my focboxes run on 12S 3P 18Ah 65C lipos so compared to current capacity to 18650 its like 8 times more than 12s10p but that’s on paper So your 12s4p is like simple pack
