Hi everyone
Question here as old as this it could be. I’ve have read all topics, but i would be happy to hear some more conversation on this topic since some vesc are out of stock now.
I need to get reliable vesc. Old one fried 3rd time (drv) and i dont want to give it for repair again (its chinese with heat shrink from eBay. Bought it in UK store 2 years ago. it was not the cheapest but quality turned out to be not good). And Im looking for replacement.
I have 3.5 year old setup. and last year i made a kydex case, and since its beautiful and i spend ton of time making it and its limited in space - its going to fit only 4.x vesc. not 6.x due to dimension limitations.
So any suggestions for vesc 4.x in 2020?
I need it to be reliable. I run single motor 12s 192kv setup. ill set it up to 45amps. and it will be under load regularly.
what ive found from the best options so far that is available is torqueboards vesc https:///products/torque-esc-bldc-electronic-speed-controller
and vanda vesc https://vandaelectronics.myshopify.com/products/vesc-motor-controller-custom-cables-and-connectors
i would appreciate suggestions it would be great if it can run in foc, but if not - bldc is fine. i dont like a lot of noise, but is not highest priority.
