and here is a comparison of 10S – 5:1 vs 4:1 vs 3:1 vs 2:1 gear ratios (25a bat limit per motor, 80a motor limit):
(if you switch to 10S, then gear it at 5:1, I believe you’ll get a significant boost – not in top speed but peak vehicle thrust, that said 2:1 @ 10S gives ~40mph top speed…)
I’m thinking a 4:1 ratio, it’ll have plenty of speed and quite a lot of torque and that means i’ll only need a 48t pulley on the wheel which should be ok
Just half read this post https://www.electric-skateboard.builders/t/gearing-ratio-for-torque/34348
seems he was trying to do bout the same as me. I think I will get the new battery and then try everything out then 3D print pulleys and see how well it does. maybe even add a cover for the wheel pulley depending on if I want to keep the higher wheel pulley
It’s close to the ground, but if the places you ride are relatively clean it should work
You will know if your belt start to look like a Swiss cheese
