Hi what are the mounting distances (1 and 2) on 50xx motos? I cant find anywhere… Thank you !
Should be 30mm
30mm is the 1 . And the 2 ?
If you know the radius (15mm) and it’s a 90°angle, then you can calculate the distance between them 21.2mm
It seems like the racestar motors used an odd pattern, i think it’s like 38mm across
38 is like outside diameter but not the can itself
I love high school math.
