Has anyone gotten the superstars on an 8mm axle yet? Seems like with an OD of 28mm there are no bearings that can go down to 8mm ID. @trampa makes spacers to get the bearings up to 9.25mm but not 8mm.
Any solutions?
Any solutions?
I think I’m too wide I think they are too wide outside to outside of bearings *Siri
You would have to get precision trucks and get a custom axle made at the right length and at 9.25 MM
How about 3d printing or machining some 28x22x8 rings to bridge the gap between a standard 22mm skate bearing and the 28mm bearing seats in the hubs?
We just had the discussion and there are bearings but they will only work with @torqueboards trucks
That was an option I was looking at but I’d have to have someone Machine them for me
Damn @Maxid you came in clutch! I have tb extended trucks installed. Looks like I’ll be ordering supstars
Hello. I’m latheing some aluminium hubs in a month or 2 at work. To fit 6-6.5" tyres with 608 bearing. If you haven’t found a sollution to this by then PM me and I can make a set for you
So if we have the TB wide truck and the 6.5 supa we could use the 638 because the 8mm v 9mm ID shouldn’t matter?
ID is 8mm on both - the 638 are 9mm in width though (so will be sticking out a little)
So…TB 218 trucks have a longer exposed axle than standard trucks?
Surfrodz tkp’s or rkp’s with 10mm axles solves the problem.
@barajabali did you end up with tb trucks and superstar hubs? Thinking about doing this combination with 6,5 Urban Tires and the new @Hummie deck.
Have someone done this combination of trucks and hubs and has a pic to share?
I used my tb trucks with my airless tires and they worked fine. Im sure that if you found the right bearing so would the trampa
I already gave a solution to the Superstar 8 mm axle dilemma a few months ago…
https://www.boardbumpersshop.com/product-page/trampa-superstar-hub-bearing-adapter-set
Yea there is also a bearing that fits but sticks out a mm or so. Either way works
Yours is cleaner tho
I think with Board Bumper’s kit bearings will be concealed inside. Take a look…
