Hey gang, I’ve been buying stuff left and right, but now I need some direction.
I have two 3S batteries in series, and I’m looking at placing an XT90-S loop key on the negative line to the VESC, to act as the ON/OFF key. Problem is, I have a parallel board from a friend for charging the batteries. How would I go about properly wiring this, between regular use and charging?
Do I need to get more bullet connectors that are the same size as the ones on my battery? I have a soldering tool for any connections I may need to make as well. What else do I need to get to complete the Electronics system? How should I wire this to effectively go back and forth between using and charging the board?
Also attached an image for any clarification, and for adjustment too. Much love
