I just set up a new build and did afew quick runs with no issues. Went out today after I finished up the enclosure, and mounting everything. I was accelerating hard and power just cut out. I ran a fault and got the below:
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 156.0 Current filtered : 137.4 Voltage : 28.09 Duty : 0.63 RPM : 56832.2 Tacho : 3856 Cycles running : 605 TIM duty : 4025 TIM val samp : 1937 TIM current samp : 5109 TIM top : 6344 Comm step : 3 Temperature : 33.84
Fault : FAULT_CODE_ABS_OVER_CURRENT Current : 133.0 Current filtered : 130.5 Voltage : 35.28 Duty : 0.76 RPM : 368.7 Tacho : 4875 Cycles running : 808 TIM duty : 4100 TIM val samp : 2009 TIM current samp : 4724 TIM top : 5429 Comm step : 2 Temperature : 34.42
If I try running motor detection it keeps failing with blinking red lights.
Set Up is:
TorqueBoards Dual Hubs 10s3P Li-IOn, Samsung 25R Dual VESC-x Mini RC Remote
Any ideas? It’s only one motor/vesc that’s having the issue (slave)
