I made a huge mistake and plugged the wrong balance wires into my charger and one of my lipos got charged to 4.5v. I caught it in time and drained it to 4 volts.
It was in that overcharged state for 10 or 20 minutes and it was pretty hot (60-70 celsius?) Its also a little bloated now.
I already ordered a replacement for it but is the old one still usable/salvageable? I am thinking of using it until the replacement battery comes.
Just throw the battery into a salt and water solution to slowly discharge for a couple days then once depleted dispose of normally. I definitely would not try to use it. Too much a risk of fire.
Don’t use it
Store firesafe
Discharge
As @Sander said , salt water will work and is reasonably safe. Just don’t do any experiments with it, seen plenty of Lipos go up in Flames and you don’t want that anywhere.
You shouldn’t use it at all. This is how you burn your house down by using a bad battery on a high current draw machine. That or burn your board when it catches fire lol
