Hi all,
I recently upgraded my Focboxes from 2.8 to 3.56 using the vesc tool.
However the Ackmaniac app on android which i love using does not work with this firmware, do i have to rollback to get it to work or am i doing something wrong?
Firmware is 3.56 and HW is 410
Thanks
You need to use the ackmaniac firmware.
Can you link me please to it?
My original Raptor 2 firmware worked with Ackmaniac fine…
Jinra
May 10, 2019, 3:51am
7
probably the UART baud rate. Should be either 9600 or 115200. Whatever it is now change it to the other.
I have tried both rates, none of them worked…
Should i set to ppm and uart, or just uart?
ACKMANIAC_ESC_TOOL_3_103
This is the latest firmware, i believe it should work if i flash as the “supported firmwares” list is lower than mine.
Yes, finally it works, thank you guys!
I used the ackmaniac firmware.
Some guy here was able to merge the low brake fix to the ackmaniac software. It’s really good. It doesn’t lock the wheels during low braking.
I’m going to see if I can find it.
I’m using it on my vesc6.
Same way to flash it but hit custom and go to where you save the *.bin file.
Here you go:
Use it at your own risk. It’s working great for me.
Now, if it he low brake locking doesn’t bother you, then keep what you have now.
Hey, why did you upgrade your focboxes,firmware;on the raptor 2?
This might not be answered since it has been a while. I’m surprised you still have a raptor 2.
