Does anyone know a relatively easy way I would go about adding USB ports to charge other items through my space cell pro? Any and all advice would be appreciated!
You could wire a buck converter to the discharge leads and then run a 12v-5v usb charger off that
Do you have any links to a buck converter that would work for me?
Something like this: http://www.dx.com/p/usb-powered-dc-6-24v-to-dc-5v-car-voltage-step-down-dc-converter-module-black-red-220701#.WMb-KDw8bYU
So I just bought something similar to that from another site. Is it as easy as just buying a parallel xt60 splitter and plugging the step down in one port and the vesc in the other?
I guess you could do that, but itβs just extra cables. I usually make a small cut somewhere along the wires and solder to that.
