As nice as those are they’re massively out of my price range! Didn’t want to spend anymore than £100 really as they’re going to be cheap winter wheels.
Per what I’ve seen on this fourm. Higher rolling resistance than real air tires, but if you go too fast they spin off. So ziptie them down if you are going over 25mph.
There’s also the 3d printed hubs, I’m working with them now. Front ones seemed fine, but rear hubs and the sprocket is a bit difficult to print with perfect tolerances with the cheaper printer I have. All in with plastic+printer+nuts/bolts etc… I’m well over what some sixshooters would be worth. But at least I have a printer to use for other projects.
What board is it going on? I’ve just got a set of evolve at’s for my dual rear set up and with a little messing they will work fine for the price. Six shooters are far better though but you have to pay for them.
The evolve are cheap and work. One thing with evolve though is the stepped up axle on their trucks. They go from 8mm to 10mm so you will have to sleeve the pulley bearing or source another that has 8mm bore.
I’ve got a DB Freeride 38" deck and Caliber II trucks. I was thinking of getting the Evolve ones. Even if they’re cheap. I just want something as a temporary thing
theres a guy whos making hubs out of some kind of plastic on here for pneumatics, they fit 8mm axles and you also have the trampa/mbs option if 6shooters out of your budget
