I had an Altered children’s toy electric skateboard laying around that recently stopped working.
When it was working i was reluctant to take it apart because it was pretty much the only electric skateboard I had that ACTUALLY WORKED.
It was heavy with lead acid batteries… had a low weight limit… and only went 10mph… BUT IT WAS GREAT FOR GOING TO THE STORE TO GET GROCERIES!!!
After a while it stopped working… it wouldnt hold a charge… it wouldnt move when it was fully charged… it had lost a lot of its torque over the few months ive owned and abused it… so i figured i had nothing to lose but to take it apart… the motor mount had one of those convenient cases around it that protect the pulley and what not from gravel, rain, etc… and i managed to completely remove the existing motor and mount my TURNIGY In its place…
Much to my amazement the TURNIGY motor fits perfectly, and the shaft is lined up exactly where the previous childrens toy motor was.
I’m using the same wheel pulley and belt from the childrens toy, so all i need is the exact same motor pulley to put on my motor
The motor pulley from the childrens toy is impossible to remove from the childrens toy motor as its sort of welded on as i guess they never thought anyone would ever modify it…
IT HAS 19 TEETH AND IS ABOUT 17MM IN DIAMETER… WHAT IS THIS CALLED? IN TERMS OF WHAT I SHOULD BUY?
