I couldn’t see the pins behind the jst connector. If it’s not charging it could be a bad bms. If you discover it is. I have a replacement you can use. Bestech d140 Set up for discharge directly form pack. With charge/ balance
Unfortunately the one I have, is the biggest that can fit in my setup.
I think li tech power sells a bms that size
This was bought from them.
O shit. I’m just no help.
3/4 inch deep enclosure?
It’s a 1inch, but all the space is taken, this bms was really a long shot help for my build.
I don’t think your dead in the water yet. If you could give me a bit more info. The bms we use are olny 1/4 thick. If you are able to replace a bms and the pack is from China ( 1 inch thick ) you could brake down your pack to bare minimum and put the bms on top.
Sory, my bad, my Eu unit system confused me, my enclouse is only 20mm.
Yea. You are as flat as you can go at cell size 20mm. Sorry I couldn’t help.
