Is there any benefit to using extra capacitors on the battery side of a vesc? I assume less voltage sag but does it make a difference? Or does making the battery current travel through more wires cancel that out?
Supposed to be important for voltage spikes with extended battery wires:
I was wondering the same thing the other day when I saw a lot of people’s build had the extra capacitors at the ESC.
I also noticed the capacitors built onto the Enertion Vesc, does this ESC need more capacitors, or are the board capacitors there for this very reason?
