I just bought couple of these 10S BMS. Appears to be decent so far. I’m only using them for charging only. The size is only 38x65x10mm that will fit anywhere.
Anyone else using these?
So far i’m using it instead of balance charger to see how it performs.
“Sadly” my pack is already in very good balance, so i might need to bleed one cell a little off to see what the BMS does.
The V/A-meter is from Aliexpress or some other similar place, can’t remember anymore. Integrated shunt, not external. Yes it has Ah also, but i haven’t used it. I mainly use it for monitoring device’s V/A.
Yea the BMS looks on other side like a Buffalo external HDD case. I hope it’s not just polished shit.
But this is as small that if fits on the middle section of my current board. So i can keep the existing balance connector, and charge throught that, and also monitor the voltages without opening the cover.
Yes, as you see on the very first picture. B-, charge and discharge are installed, and balancing wires with header.
I don’t personally like that those wires are installed. I’d rather solder them myself than extend the installed wires.
