Any good portable chargers?
Um yeah does anyone know of a good portable charger for on the go
What exactly are you looking for? We even don’t know for which voltage…
@Kingdom421 Give us more info. BMS or balance charger? Voltage? Current? Battery chemistry?
Let me check real quick its not for a diy it’s a prekit
I had to leave real quick so all I know it’s a Lithium 3200mAh
The voltage, your desired charge current and the adapter plug type we need to know as min.
You can use this one for 10s to 12s up to 7,5 amps charge Meanwell hlg-320h-48b Is cc-cv, the best thing is no noisy fan. Also not the cheapest.
@Surfer Yeah, no. That’s a LED driver, not a battery charger. It’s not designed to charge batteries, and it has no current ramp-down or charge termination. It’ll charge your battery all the way to 4.2v/cell at maximum current and continue to trickle charge it indefinitely once it’s there. That’s a PERFECT recipe for a battery fire. Do NOT use that thing to charge your batteries.
You can make your own with a boost converter, spare Lipo and watt meter
Oh yeah I see that you don’t have any clue about what you are talking about :slight_smile:
1548950065195
Which charge plug you have? How much amps the charger should have?
12amps USA Wall plug
Have a look at this one
Is it the same charge plug than you have?
Your charger is 2.5A :wink:
I have that already I’m looking for something portable I can plug it into so o don’t have to find an outlet. I guess it’s call a power bank.
This is what I’m thinking about trying. https://www.rockpals.com/products/rockpals-280wh-portable-generator-rechargeable-lithium-battery-pack-solar-generator-power-station-with-110v-ac-outlet-dc-output-usb-output-for-cpap-backup-emergency-hurricane-storm-and-outage-camping?variant=13342825349189&gclid=Cj0KCQiA1sriBRD-ARIsABYdwwHr_I_UonNpspYcsmFJXG5W0a4z5lFyhws7Aexyo0vyaPWxK-LpvkwaAueeEALw_wcB
You need to say what you searching… We can’t read your mind…
Haha oops bro my bad I’m just waking up i meant to attach this https://www.rockpals.com/products/rockpals-280wh-portable-generator-rechargeable-lithium-battery-pack-solar-generator-power-station-with-110v-ac-outlet-dc-output-usb-output-for-cpap-backup-emergency-hurricane-storm-and-outage-camping?variant=13342825349189&gclid=Cj0KCQiA1sriBRD-ARIsABYdwwHr_I_UonNpspYcsmFJXG5W0a4z5lFyhws7Aexyo0vyaPWxK-LpvkwaAueeEALw_wcB
