If you haven’t already, read this first
Second, buy cheap, buy twice.
Like @Linny said, stay away from that site.
Like @Andy87 said, for off-road go with 40c lipos at least.
Quality motors are Maytech or @JLabs motors. It all depends where you are in the world.
User feedback says to not purchase 4.2 dual. But 4.2 plus maybe.
And the most important is safety gear. Medical bills are far more expensive and not so pleasant to have as just a broken board.
Also consider reading this series
https://forum./t/building-a-lightning-powered-murder-board-part-1/119?u=grozniy
As the others have mentioned, the parts list is a bit weak overall. I would highly suggest a good further read and not to rush in to it. Trust me, you’ll think you’re ready to assemble and something will be missing anyway. Rushing will just waste money.
5Ah of batteries is also a little small, especially for a dual setup. I’d recommend either bigger lipos or 18650s. Spend the money on a really solid battery, it’s the heart of your build.
Flipsky is currently working on a fix for the cutout issue for their 4.20 hardware versions.
Another member of this forum and I have verified that the proposed change (well, we figured it out in the first place) makes the 4.20 (original and plus) versions even more bulletproof than some of the best 4.12 hardware versions.
(By that I mean we ran ± 60A motor current on FOC with sensors, and full throttled the test board up a steep hill, ran this test several times)
I would wait until Flipsky implements the change, unless you are able to make the change yourself. It’s not a difficult rework, but is very tedious, especially for those who may be less experience with SMD soldering.
if you’re building an all terrain board i’d go with four of those lipo’s. 2 in series 2 in paralel for 10s2p. MTB’s need a lot of power so you’ll need a big battery if you want some decent range. the ESC is not bad and as for motors go 190 or 170KV. buy your motors as big in size as your budget will allow
