hi all - looking for a deck to install @psychotiller SixShooters.
I have a good deal for the Landyachtz decks below. What do you think? Wheel bite would be an issue?
http://landyachtz.com/nine-two-five-horror or http://landyachtz.com/drop-speed
Assuming your using 180mm trucks or wider you are golden.
Using TB218! Hope its ok then
@mmaner Worried about two things on “9 to 5” version 2014:
i have the 925 and the W shape is awesome!
Rocker is nice to have, it helps find your place on the deck if nothing else. I cant be positive you won’t have wheel bite, but its unlikely and if you do you can always add risers.
Nice to know! Can you pls send pics? How is the flex?..any issue with the enclosure? tried to search your build, could not find it
risers, or a little strategic cutting…
